Author Topic: Deeper steering / drag / center-link  (Read 1222 times)
Offline LukeSkywalker
  • Plymouth
« on: September 29, 2013 - 03:39:12 PM »
Mayday. Mayday.
I've changed the oil pan, and now I can't get the steering rod / drag / centerlink to fit properly as it touches the oilpan underneath.
Are there deeper drag / center links around anywhere that fit a 70 Cuda with 440?
The one I have now looks like this: (if you scroll down you'll find pics)
http://www.ebay.com.au/itm/Mopar-Dodge-Plymouth-B-E-Body-Steering-Drag-Link-/330941839484?pt=Vintage_Car_Truck_Parts_Accessories&hash=item4d0dabb87c
« Last Edit: September 29, 2013 - 03:49:35 PM by LukeSkywalker »
Offline ToxicWolf
Re: Deeper steering drag / center-link
« Reply #1 on: September 29, 2013 - 03:43:25 PM »
 :popcorn:  Curious too.
Offline dutch
Re: Deeper steering / drag / center-link
« Reply #2 on: September 29, 2013 - 05:00:33 PM »
how much space do you need?
*** Bart ***
« Reply #3 on: September 30, 2013 - 10:49:59 AM »
No, there is no such center link out there, but this is not an uncommon problem for mopars.
Look at this thread about the recommended solution. This is straight out of the Mopar manuals, so this is the factory recommended method of creating oil pan, center link spacing.
http://www.cuda-challenger.com/cc/index.php?topic=95187.0
Offline HP_Cuda
  • Mopar or No Car!
« Reply #4 on: September 30, 2013 - 11:49:43 AM »
I think there is some variance you can play with but in the end it's picking the right oil pan...
« Reply #5 on: September 30, 2013 - 03:41:45 PM »
...and motor mounts, and trans mount, and verifying mounting pad dimensions, and...
Center link interference is usually the stack up of tolerances from all of the items listed above. Add into that factory assembly tolerances, which at some points is as loose a .125", and you have a formula for interference. Hence the factory recommendations for shimming and grinding/welding.
  • Plymouth
« Reply #6 on: October 03, 2013 - 12:05:42 PM »
I only needed 1,5 cm.
Since a deeper centerlink don't exist, I ended up pressing a small dent across the oil pan, as the sheet metal was so soft it didn't hurt it much.
Worked out great, looks good. Tnx for your help :)
« Last Edit: October 03, 2013 - 12:07:27 PM by LukeSkywalker »
Offline HP_Cuda
  • Mopar or No Car!
« Reply #7 on: October 03, 2013 - 12:16:15 PM »
Luke
Great news, I was going to ask if you could press an indent without hurting it.
Glad it worked out for you.
Bryan
