I'm planning to cover my floor pan and firewall with Dynamat after applying a coat of POR-15. When I pulled the stock fiberglass insulation out, there were a number of the plastic pins missing that were supposed to hold the insulation pads in place. Most of these unplugged firewall holes had some amount of rust running downhill like what's shown in the picture. I don't think the Dynamat needs the pins to stay in place, but should I insert the pins through the Dynamat anyway to fill the holes? Not worry about filling them? Would I be better off cutting the head of the pins short so they fill the holes and then cover with Dynamat? This last approach seems to make the most sense to me, but I would really welcome hearing what others have found works or doesn't work.
