Author Topic: Rim blow wheel squeak  (Read 608 times)
Offline ad263210
« on: March 03, 2015 - 12:30:15 PM »
Hello,
I have been experiencing a steering wheel squeak with my newly installed rim blow wheel. Any tips or suggestions on a possible fix?
The shop working on it says they lubed the contact points up, but the squeak still persists. Perhaps there is a certain type of grease needing to be used
Thanks,
Anthony
Offline OUTLAW
  • MASTER OF ALL THINGS MOPAR
  • I didn't say you can't RACE--I said you can't WIN
    • MOPAR-MADNESS  WEB/FORUM
Re: Rim blow wheel squeak
« Reply #1 on: March 03, 2015 - 06:54:54 PM »
still sounds like they missed a spot  or there is a burr on one of the contacts - some super fine sand paper might do the trick then re grease them
« Reply #2 on: March 03, 2015 - 07:27:41 PM »
I cannot see how the rim blow could squeak , it only bolts to the crush can , it has to between the shaft & housing where there is a brg  or between the crush can & housing
Offline OUTLAW
« Reply #3 on: March 03, 2015 - 09:29:41 PM »
I was talking about the horn contact or brush in the column ...not the rim blow itself.
there should be a carbon brush and a contact ring at the base of the steering wheel/ top of the column unless things have changed and they honk the horn using infrared or wireless :dunno: [size=78%] [/size]
« Reply #4 on: March 03, 2015 - 10:32:15 PM »
if it is a factory TS switch the horn contact is a roller wheel
