Author Topic: Tach voltage Rallye dash  (Read 1243 times)
Offline moparstyle
« on: May 28, 2015 - 09:28:22 AM »
Cleaning up the wiring behind the dash. Some previous owner has been very creative...
The tach in a Rallye dash, does it get 12 v or "reduced" v from the voltage limiter?
Hmmm, my FSM does not show a limiter in the Rallye dash (but the standard dash has one). Should there be a limiter in a Rallye?
Finally, the turn signal flasher relay, is it the same type of relay for the em flasher?
Thanks!
72 Challenger, 440 stroker, 727 (70 clone)
70 Barracuda Gran Coupe
And on the side:
67 Pontiac GTO
63 Lincoln Continental
Offline JayBee
Re: Tach voltage Rallye dash
« Reply #1 on: May 28, 2015 - 10:02:21 AM »
Rallye dash tach IS 12 volts.
Rallye dash SHOULD have a 5 volt limiter.
Not sure if the flashers are the same.
Highly recommend using a solid state 5v limiter.
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline moparstyle
« Reply #2 on: May 28, 2015 - 09:20:59 PM »
JayBee, thanks!
Let me pick your brain some more on this. Have new gauges in so i want the voltage correct.
So:
tach (and clock) 12 V. Temp / oil press 5 V.
Fuel gauge? My old one works and it has 12V. By that i can safely assume that 12V is correct?
Pls also comment on the wiring hook up on the limiter.
Red / yellow wire 12 V in, black wire on top 5 V out. Correct?
Thanks, Jerry.
And on the side:
67 Pontiac GTO
Offline JayBee
« Reply #3 on: May 29, 2015 - 09:56:47 AM »
Yes, tach and clock are both 12v
Stock temp., oil, and fuel are 5 volts. I have no idea whats up with your fuel gauge.
Here's a picture of a stock rallye dash 5v limiter wiring. The empty spade connector on the limiter is for 12 volts.
The red/yellow (12v)doesn't look stock, it was originally black (wire# G1 - 18BK)
Top black IS 5 volts out.
John
2014 Toyota Avalon
Offline moparstyle
« Reply #4 on: May 29, 2015 - 12:10:39 PM »
Ok, now I got it. My fuel gauge is not stock, must be a 12 volt replacement from whatever... does not look as in your pic.
Thanks for clearing this up!
And on the side:
67 Pontiac GTO
