Author Topic: Manual Choke Cable Location - proper parts etc  (Read 1083 times)
Offline wantone
  • (O O {]{]{]||[}[}[} O O)
« on: August 28, 2015 - 10:12:41 AM »
Howdy!  My cuda doesn't have a choke but my carburetor is an Eddelbrock 1407 - which has a manual choke.   Sooo I figure I best install a choke cable  etc.   What do they look like normally and who'se is the best to use?
Want one?  Got one! ... finally
Re: Manual Choke Cable Location - proper parts etc
« Reply #1 on: August 31, 2015 - 09:29:43 PM »
 They never used a manual choke from the factory so it is up to you how & where you want to add one , you can run the cable through a speedo grommet or similar instead of drilling another hole in the firewall .
 There are conversion kits for an electric choke on the carb you have then you can just tie in to 12v power source [blue wire] to the alt or voltage reg which would be more preferable in my mind as it is automatic .
« Reply #2 on: August 31, 2015 - 11:05:52 PM »
1971 Hemi's were manual choke.  From the Factory.
Offline wantone
« Reply #3 on: September 01, 2015 - 10:44:21 AM »
Awesome Gents-  thank you both!
