Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Interior and Gauges
(Moderator:
Chryco Psycho
Electronic ignition / Tach
« previous
next »
Print
Pages: [
1
Author
Topic: Electronic ignition / Tach (Read 1793 times)
BadJoey
Full Member
on:
July 28, 2015 - 07:29:48 PM »
I changed from points to electronic ignition will that affect my tach readings ( rally dash ) . According to my friends timing light ,has tach built in , My rpm's on light is 750 , inside tach is 1200 .Any thoughts ? As always Thank You.
Logged
tman
Sr. Member
Re: Electronic ignition / Tach
Reply #1 on:
July 28, 2015 - 08:20:38 PM »
I would hook up a 3rd tach to confirm. Also depends on the ignition system you got. You did not mention what electronic system you installed.
Logged
JoeGrapes
Full Member
Reply #2 on:
July 28, 2015 - 09:14:08 PM »
It shouldn't. With either ignition the tach is connected to the negative side of the coil. I agree this calls for a 3rd opinion. Either your tach or timing light is wrong.
Logged
JoeGrapes
Full Member
Reply #3 on:
July 28, 2015 - 09:19:20 PM »
Oh sorry, I was assuming you were using a Mopar Electronic Ignition. If you are using an MSD ignition then you need a tach adaptor from MSD to get the factory tach to read right.
Logged
BadJoey
Full Member
Reply #4 on:
July 29, 2015 - 11:17:02 AM »
Mopar electronic ignition . I'm thinking the car tach is off . Thanks guys
Logged
HP_Cuda
Hit the skinny little pedal on the right!
Sr. Resident
Mopar or No Car!
Reply #5 on:
July 29, 2015 - 12:49:12 PM »
You will find that some tach's don't work well with certain electronic ignitions and require an adaptor to make it more accurate. Check your manufacturer and they will probably have a tech note on it.
My last tach was this way and I pitched it, it was an Autometer tach.
Logged
Cardude
Newbie
Reply #6 on:
August 31, 2015 - 04:33:03 PM »
Most '60s tachs won't work with modern electronic ignition, mine wouldn't work after I got rid of my points distributor so I sent it to AutoInstruments for a tach conversion and now it works perfectly.
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
Interior and Gauges
(Moderator:
Chryco Psycho
