Author Topic: My speedometer are broken...  (Read 2544 times)
Offline Suulan1
« on: August 14, 2015 - 04:16:43 PM »
My speedometer are broken...  :hyper:
My question for you guys is,  if i buy a new one,  is there a problem if i want to change the backplate (where all numbers and "mph")  are,  to my old one?
The thing is that i got a original dodge challenger KPH speedometer and really want it to remain that way.. I dont want a MPH nor a MPH/KPH...  I got a pretty rare original europe car..
Offline Racer57
Re: My speedometer are broken...
« Reply #1 on: August 14, 2015 - 05:22:37 PM »
Offline js29no
« Reply #2 on: August 14, 2015 - 05:26:00 PM »
How about auto instruments . com
Offline roadman5312
« Reply #3 on: August 14, 2015 - 05:28:06 PM »
Contact Redline.
http://www.redlinegaugeworks.com/default.asp
                                        :iagree:  And ask about converting to GPS speedo.  Cool stuff.  :2thumbs:
        :rebel:
Offline js29no
« Reply #4 on: August 14, 2015 - 05:31:06 PM »
Not trying to hi jack this but what is A gps speedometer all about.
Offline tman
« Reply #5 on: August 14, 2015 - 05:31:37 PM »
First of all, did you eliminate the speedo cable is not working right?
https://www.youtube.com/watch?v=zdYM0dXzbOI
Also in addition to Redline, this place can reface or refurbish your kmh face.  Go down 3/4 of the page.
http://www.tachman.com/mopar.htm
« Reply #6 on: August 14, 2015 - 06:27:50 PM »
I got my GPS speedo from here... http://www.speedhut.com/about-speedometers.html No speedo cable required.
They can make what ever design you can come up with. I designed mine to look like stock but went with 140 MPH.
http://www.cuda-challenger.com/cc/index.php?topic=102488.0
Offline roadman5312
« Reply #7 on: August 14, 2015 - 06:38:58 PM »
                                                    :iagree:  We had Redline do the GPS. amp to volt and custom grafics. Came out awesome.
        :rebel:
Offline JayBee
« Reply #8 on: August 15, 2015 - 07:34:49 PM »
Is it a rallye speedo. You can grind off the original semi-tubular rivets and switch the face. I know Mr. Heaterbox and Instrument Services will sell the rivets individually. The ones from Mr. Heaterbox need to be painted.
Keep in mind that if you buy a new speedo, the odometer and trip odometer are probably geared for miles, not kilometers. You'll probably have to swap out that gear from your old unit.
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline Grec
« Reply #9 on: August 24, 2015 - 12:34:32 PM »
"First of all, did you eliminate the speedo cable is not working right?"
Or even the speedo gear in the transmission. Mine got chewed up somehow and the speedo didn't work until I replaced it.
1973 Challenger Rallye
- 440 Six Pack
- A833 4 Speed, 18 Spline
- FE5 Rallye Red on Black
Offline Cardude
  • Newbie
« Reply #10 on: August 31, 2015 - 04:29:02 PM »
Call AutoInstruments.com.  They can rebuild your original speedometer and have the correct rivets to reassemble it and your mileage will stay the same.  The original speedometers also look much better than the repros.  I didn't have much luck with a repro for my wife's car.
