Thermostats
Author Topic: Thermostats  (Read 1159 times)
Offline daveh
Thermostats
« on: June 09, 2016 - 02:06:10 PM »
Hey guys,
I'm putting together my 340 and I'm not sure which thermostat to use the 160 or 180.  I have both below.
It's a mildly built 340.  Thanks
http://www.summitracing.com/parts/mil-16405/overview/make/dodge
http://www.summitracing.com/parts/mrg-4367/overview/make/dodge
Offline Mopar Mitch
Re: Thermostats
« Reply #1 on: June 09, 2016 - 02:31:07 PM »
Pending where you live (hot/cold), how you drive, as well as your radiator/fan/shroud setup, see if your engine can by with the 180 (actually, I think a 190 is recommended by Chrfysler/Mopar) for our cars.  I've tried used a 160 (Chicago 'burbs area, summer only) and it'll run cool until I do road course lapping sessions (~20-30 minutes per session)... then I have to flip the heater on full blast to help reduce the heat... and a 180 didn't help except if running in cool weather (spring or fall).   I'm planning to get a larger radiator, and likely aluminum.   180~190 helps make the engine more efficiently.... colder temps not so good for cylinder wear in the long run of the engine's life.
Offline daveh
Re: Thermostats
« Reply #2 on: June 09, 2016 - 03:01:38 PM »
I live in South Florida if that makes a difference.
Re: Thermostats
« Reply #3 on: June 10, 2016 - 09:20:29 AM »
the coolest I use is 180 * so that would be my suggestion , 160* is too cold
Offline daveh
Re: Thermostats
« Reply #4 on: June 10, 2016 - 09:58:10 AM »
That's what I was thinking.  Thanks for the confirmation.
Offline tman
Re: Thermostats
« Reply #5 on: June 10, 2016 - 12:42:43 PM »
180
Offline YellowThumper
  • I left the snow for this?
Re: Thermostats
« Reply #6 on: June 10, 2016 - 04:14:43 PM »
180 here also.
Warmer engine provide better atomization of fuel. Main reason in past years the oems (before FI) went with the 195 degree ones.
Re: Thermostats
« Reply #7 on: June 10, 2016 - 10:27:45 PM »
Ok, I'll be the odd guy out. 180* is too cold unless you are at the strip. Your engine will prefer a 190-195*.
Re: Thermostats
« Reply #8 on: June 11, 2016 - 01:06:40 AM »
I would not argue against the 190/195 but would argue against the 160
« Last Edit: June 11, 2016 - 11:24:03 AM by YellowThumper »
Offline brasil
Re: Thermostats
« Reply #9 on: June 11, 2016 - 03:20:09 AM »
I am running a 180 °F Thermostat....but only because till now I couldn´t find a Highflow Thermostat in 195 °F....     195°F  is the best you can run...if your cooling system is in good shape !!
Greetings Juergen
