Trying to get an idea if any of these parts have any value or should be scrapped.
All from 71 Challenger RT.
Entire Rear 8.75, drum to drum with leafs.
Entire front k frame, large discs. Complete discs to discs, shocks, torsion bars, gear box.
Original AC/Heat Box. Could likely use a resto.
Is original sheet metal worth anything?
Upper cowl panel a decent bit of rust through in the usual areas and a dent or two. I replaced it with a complete replacement, but I am also not going with a full original resto.
Original trunk pan, same kind deal of deal. Needs some rust repair. No sense fixing it when a full replacement can be had for my resto.
Dash/Frame
A couple sets of front seats, misc condition missing covers, lowers etc.
Full steering column with wheel, could use some wiring repair and restoration.
Thanks
