does anyone know why energy suspension does not make a lower control arm bushing for the e body?
the energy suspension lower control arm bushing kit is complete minus the lower control arm bushing. I feel if you are going to go through the trouble of replacing your bushings these are the ones you want to swap out the most.
i have a 1970 cuda and i am replacing the oem lower control arms with a set that has factory sway bar brackets. before swaping the new ones in i want to replace the bushings.
while on topic, does anyone know where i can find a set of bushings?
cuda70gt
