Author Topic: rear shocks  (Read 1690 times)
Offline garyp
rear shocks
« on: November 23, 2016 - 05:59:29 AM »
 I am working on a 1973 challenger and noticed that the rear shocks in the car are air shocks.  was that stock on the car ? and is there any reason when replacing them that I should go with air shock  or go with standard shock ? thanks
Re: rear shocks
« Reply #1 on: November 23, 2016 - 08:44:59 AM »
Not stock, usually they are masking worn out springs. They can damage the mounting crossmember as it was never designed to support the weight of the car. I had them in my car when I first got it  and quickly replaced them. ( and the springs)
Re: rear shocks
« Reply #2 on: November 23, 2016 - 09:13:16 AM »
The upper shock x-member isn't very strong.  It's only spot welded to the frame rails in a couple spots.  If a car has had air shocks for awhile, you'll see that the x-member breaks it's welds and separates from the frame.  The proper thing to do is replace the sagging springs and install a standard style shock.  A cheaper alternative to brand new springs, is adding an extra leaf to your existing spring pack.  The choice is up to you depending on your budget and mechanical ability.
Offline blown motor
Re: rear shocks
« Reply #3 on: November 23, 2016 - 12:36:37 PM »
Where are you located? I have a set of KYB that I took off last year to put Bilsteins on. If you're interested in them let me know.
Offline garyp
Re: rear shocks
« Reply #4 on: November 25, 2016 - 05:01:57 PM »
I am in Rhode island, how much would you want for them  ?
Thanks
Offline dfrazz
  • 1970 Cuda - 1968 Charger
Re: rear shocks
« Reply #5 on: November 25, 2016 - 09:49:18 PM »
KYB's suck (sorry Blown Motor but they do).  Go get a set of Bilsteins, best bang for your buck.  PST has them and has a sale on now.
Offline blown motor
Re: rear shocks
« Reply #6 on: November 25, 2016 - 10:23:10 PM »
Bilsteins are for sure better but you pay a lot for them.
Offline dougs bs23
Re: rear shocks
« Reply #7 on: December 05, 2016 - 08:41:38 AM »
I did the "addaleaf" and kyb's. which lifted the rear about 2". As for the shocks, I think they ride like a truck and don't really like them. Bilstiens are on the what's next list maybe over the winter
Offline HP_Cuda
  • Mopar or No Car!
Re: rear shocks
« Reply #8 on: December 05, 2016 - 01:23:23 PM »
 :iagree: :2thumbs:
