Author Topic: 1970 Plymouth Barracuda Hardtop and Coupe E-Body Window Felts Fuzzies Full Kit  (Read 567 times)
Offline JoshsMuscleCarParts
  • Sponsor
Josh's Muscle Car Parts January Specials
1970 Plymouth Barracuda Hardtop and Coupe E-Body Window Felts Fuzzies Full Kit 8 piece $101.26 With Code PHIL At Checkout
Our Cuda window felt kits are made right here in the USA. Each kit is made to fit correctly into your car. Most kits are available in two options "replacements" and "OEM". OEM style kits utilize Original Equipment Manufacturer type materials and appear very close, if not identical, to the original once installed. Replacement style kits utilize replacement materials that differ slightly in appearance from the original.
If no option is given below, then your kit will be the OEM style.
http://www.musclecarparts.cc/shop/item.aspx/1970-plymouth-barracuda-hardtop-and-coupe-e-body-window-felts-fuzzies-full-kit/636/
Cuda-Challenger Forum members save with coupon code PHIL at checkout.
« Last Edit: January 31, 2017 - 10:53:29 AM by JoshsMuscleCarParts »
