Author Topic: Screw dimensions  (Read 1009 times)
Offline 4yuckfous
Screw dimensions
« on: July 08, 2009 - 01:57:30 PM »
what exactly means the digits behind a screw dimension
for example 7/16 -20
or 7/16 - 24
The streets don't get wider, if you drive slower !
wagesofsin
Re: Screw dimensions
« Reply #1 on: July 08, 2009 - 02:26:45 PM »
for example:  7/16-20  is 7/16 bolt , 20 threads per inch.
Offline 4yuckfous
« Reply #2 on: July 08, 2009 - 02:33:47 PM »
Thx
I love our metric screws much easier
« Reply #3 on: July 09, 2009 - 01:47:42 PM »
It really is pretty simple. Threads are bascially fine or course. The bigger the number, the finer the threads.
Ya know, I've run into various pitch metric fasterners, so they have variations as well. For example, you can get M8 in either a 1.25 or 1.5 pitch
Offline quagmire
  • Traction Impaired......
« Reply #4 on: July 09, 2009 - 03:24:14 PM »
Yeah, some of the metric sizes can have as many as 3 different thread pitches for a given bolt size.  I believe M10 or M12 are that way.  Found that out when I had to retap a hole, guess which of the three taps I ddin't own or could find easy?   :eek4:
Offline 4yuckfous
« Reply #5 on: July 13, 2009 - 06:37:34 AM »
Offline the_engineers
« Reply #6 on: July 14, 2009 - 02:56:34 PM »
US or SAE threads are the same way...most are available in two sizes, UNC (Coarse) and UNF (Fine) and some are available in UNEF.
Here's a link that may help with the confusion.
http://en.wikipedia.org/wiki/Unified_Thread_Standard
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
