Author Topic: If I have the switches and motors how hard is it go go PW??  (Read 1222 times)
Offline gomangoRT/SE
« on: February 02, 2006 - 01:52:57 PM »
I would think a man could cut out the places in the doors to make them PW door panels.   At least I think so.   Then of course you have to wire the motors.  But do you need any other brackets or anything to attach motor assemblies to the window channels?    Is this a reasonably doable project?
Secondly, it does not show up on the fender tag whether the car was a Power windows car does it??
Offline FY1 RT SE
Re: If I have the switches and motors how hard is it go go PW??
« Reply #1 on: February 02, 2006 - 02:42:09 PM »
You also need the regulators.
P31 on the Fender Tag
« Reply #2 on: February 02, 2006 - 02:49:17 PM »
gomango,
  I believe Mike Tyler can fill you in on all that is involved with this conversion. I seem to remember it was quite an interesting adventure for him.
Offline miketyler
    • www.miketyler.net
« Reply #3 on: February 02, 2006 - 03:05:51 PM »
yes, been there and and almost finished with that. However, I used the aftermarket regulators that bolted right in to my manual door. I cannot speak to any differences in a manual door and an OEM power window door. I am using OEM switches so they will have the OEM "look".
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
« Reply #4 on: February 03, 2006 - 12:12:26 AM »
the power regulators will bolt into any door originally with crank windows or not
Offline miketyler
    • www.miketyler.net
« Reply #5 on: February 03, 2006 - 09:03:41 AM »
Quote
Thats what I would have assumed that all doors are basically the same
72' Cuda restomod
70 Mustang Mach 1
« Reply #6 on: February 03, 2006 - 09:25:35 AM »
Mike.........  I sent you an email.   Tks  Kevin
