Author Topic: B5 Blue interior question---dash corner, window trim color...  (Read 1544 times)
Offline AARudy
  • 1970 4-speed AAR---71 Cuda conv----70 Chall 440-6
« on: January 16, 2006 - 07:25:13 PM »
Hey guys....the dash corners, and window trim, pillar covers etc....is there a paint code for this? How do I find out...is it the same B5 as the exterior of the car?? Thanks.... ???
Offline Carlwalski
Re: B5 Blue interior question---dash corner, window trim color...
« Reply #1 on: January 16, 2006 - 07:32:13 PM »
As far as I'm aware they were all variations of the shade.
I would go by what you have most of, eg: the seat covers and dash.
If the seat covers and dash pad are the same color match it off them.
Chances are your carpet, console and door panels will be slightly off.
That is the way Chrysler made them anyhow, so you could get everything to match, though it will be hard.  :thumbsup:
 :2cents:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
« Reply #2 on: January 17, 2006 - 11:07:18 PM »
interioir color code would be B5
Offline AARudy
« Reply #3 on: January 18, 2006 - 11:39:57 AM »
thanks for the input you guys...
Rudy
qluber1
« Reply #4 on: January 19, 2006 - 05:30:27 PM »
There are in fact 2 different colors used in the interior of a B-5 coded interior. The standard color codes are from PPG. I will retrieve these codes for you if you would like but I need a year model. The dash and surrounding trim are a darker blue as well as the console (if applicable).
« Last Edit: April 10, 2006 - 03:30:34 PM by Rev-It-Up »
Offline AARudy
« Reply #5 on: January 19, 2006 - 07:29:22 PM »
looks good! If you had the codes, that would be great! It's for my 1970 AAR Cuda...
Thanks for the pics... :thumbsup:
qluber1
« Reply #6 on: January 22, 2006 - 04:41:26 PM »
These are the correct Ditzler codes which can be crossreferenced to PPG.
Bright blue- 13848
Med. blue- 14090
hope this helps
Offline AARudy
« Reply #7 on: January 24, 2006 - 08:28:33 AM »
thanks for those codes!! That helps me alot...
Rudy :bigsmile:
