Author Topic: Turn signal relay  (Read 827 times)
Offline GreenFish
Turn signal relay
« on: February 02, 2006 - 11:08:35 AM »
Hey folks,,
trying to figure out why my turn signals dont work.. Trying the easiest first.  Is the turn signal relay the one under the dash that is near the ash tray?
if so .. can you provide a part number or where to get it?
thanks
joe
 :banghead:
Offline hemi71
Re: Turn signal relay
« Reply #1 on: February 02, 2006 - 07:27:01 PM »
Do you mean the flasher? There is no relay in the turn signal circuit. If the lamps lite when you switch the signals on, but do not flash, then the flasher is bad. It's a standard 2 prong flasher, available at any parts store. If the lamps do not lite at all, you may have a bad fuse,switch, or an open flasher (not likely) or wiring problems.
« Last Edit: May 23, 2006 - 03:11:17 PM by Rev-It-Up »
Offline toplescuda
« Reply #2 on: February 04, 2006 - 07:13:14 AM »
depends on what year the car is on a 72 the relay is behind the the ashtray  other years its down by the fuse box   and no thay dont enterchange
