Author Topic: Will 70 Challenger doors work on a 73 without problems?  (Read 963 times)
Offline jeryst
« on: August 18, 2006 - 10:25:38 AM »
I found a guy who has a set of really nice 70 Challenger door shells, and I want to use them on my 73. I have to pick them up within the next day or two, so I need a quick answer. I just want to make sure that all of the internal stuff (window tracks, lock mechanisms, etc) will all transfer over from my doors. I think everything should work, but I'd feel a lot better if I got the word from some experts. Also, is there anything I should watch out for, internally? They are rust and bondo free because they came from a western car. Thanks
Offline fishn4cuda
  • Cuda Fan!
  • Ft. Jennings, OH
Re: Will 70 Challenger doors work on a 73 without problems?
« Reply #1 on: August 18, 2006 - 10:43:34 AM »
Everything will work. The only differences I know of are the mounting hole space for the mirror and the outer catwisker (outer window felt). The 70's had snap in clips and the other years had screws to hold it in place. If you order new felts, just make sure you order them for the 70 doors. :2thumbs:
Cant kill the mean and ugly. Only the good die young...I plan to be here a while!!
Offline ShelbyDogg
« Reply #2 on: August 18, 2006 - 12:57:30 PM »
Make sure that you change your door latches into the '70 doors or else you'll only be able to lock your doors with a key, from the outside.
Offline Wang
  • "just hangin' out"
    • valleyautoworks.net
« Reply #3 on: August 19, 2006 - 09:31:03 AM »
Not  necessarily a bad thing, you can never lock you keys in your car :2thumbs:
Hurry,, Duane the tub,,I'm Dwouning....
Offline jeryst
« Reply #4 on: August 20, 2006 - 12:22:05 PM »
I decided not to get these doors. It turns out that they are from a race car, and  there are large pieces cut out of them on the back side, where the door latch goes. I assume it was to make clearance for the rollbar setup. The guy said I could have pieces welded back into it, but I don't want to go that route. Anyway, I'm still looking for a nice set of 73 Chally doors.
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #5 on: August 20, 2006 - 09:04:48 PM »
