Author Topic: Suggestions  (Read 597 times)
Offline Hopalong
  • HEAD OFF! Apply directly to the neck line!
Suggestions
« on: August 20, 2006 - 12:21:25 PM »
Well, I've almost got my rotisserie done, and was looking for some info on the best way to start the body work.  I need to replace the quarters (or are they third's since it is a two door? :eek4:) and was wondering if would be better to do them on the ground, or mounted to the rotisserie.  I also plan on doing the outer wheel wells as well.  I plan on adding frame connectors, agian, same quesiton.  My goal is to get the body work done, then the suspension, then the drivetrain and interior.  Good greif this is slow going! :horse:
{oo/===\oo}
Offline LugNut
  • Future 50 footer 'Cuda
Re: Suggestions
« Reply #1 on: August 22, 2006 - 04:01:38 PM »
Well ... I'm sure it's been done in many ways ...
They are of unibody construction, so for doing my trunk, extensions, one quarter, and one patch I've distributed the weight over four jack stands (and the two front wheels).  So hopefully when the new metal is on, and the rear axle put back on the ground, the body's metal will be appropriately loaded and aligned.  But who knows ... check back in a year or so.    :dunno:
 :bananasmi   LugNut    :bananasmi
My '71 'Cuda Restification pages:
(Down for a quite while; changed ISPs twice)
The 1964-1974 Barracuda Web Ring home page:
(Was the last ringmaster; RingSurf is currently a zombie host)
