Author Topic: removal rear quarter glass  (Read 1412 times)
Offline 30below
« on: August 26, 2006 - 08:09:27 AM »
Read the service manual,but cant figure it out.I got the fronts out okay.Any help?
Offline 30below
Re: removal rear quarter glass
« Reply #1 on: August 26, 2006 - 08:10:09 AM »
Its a 73 Cuda.
Offline LugNut
  • Future 50 footer 'Cuda
« Reply #2 on: August 27, 2006 - 06:03:18 AM »
Just removed mine this summer.  It was siliconed-in, and was horrible to remove.  One of those angle-knives should have worked, but didn't.  A piano-wire cutters may have worked, but I didn't have one, nor someone to help at the time.
What did work, slowly, was to use a razor-blade paint-scrapper, from both the inside and outside, to slowly cut the glass from the silcone sealer (and what was left of the old gasket).
I picked up a six-pack of the new gasket material recently.  I'd be willing to part with four rolls if anyone is interested.
 :bananasmi   LugNut    :bananasmi
My '71 'Cuda Restification pages:
(Down for a quite while; changed ISPs twice)
The 1964-1974 Barracuda Web Ring home page:
(Was the last ringmaster; RingSurf is currently a zombie host)
Offline 30below
« Reply #3 on: August 27, 2006 - 08:08:34 AM »
So this glass is not attached anyplace else except with silicone?
Offline heminut
« Reply #4 on: August 27, 2006 - 09:15:45 AM »
No, LugNut missread your post. He is refering to the back glass, not the quarter glass.
1970 5.7 Hemi Cuda
Offline LugNut
« Reply #5 on: August 27, 2006 - 10:48:34 AM »
Yep, I did.  Was too early, I guess.  Rear quarters are attached from below/inside.  But if you also remove your rear glass, hope my previous info helps.
Offline mmccarty
  • My other ride...
« Reply #6 on: September 01, 2006 - 06:51:42 PM »
I just pulled one out of my Cuda tonight.  I don't know if this is the correct way...
There is a single bolt attaching the regulator arm to the window.  Remove that
and unbolt the regulator from the chassis and the regulator will come out.
From there I removed two nuts holding the guide to the chassis and the lower bracket.
These nuts go on slotted bolts to adjust the glass from side to side with a screwdriver.
I unscrewed these and removed them from the assembly.  It was a tight fit, but I was
then able to pull the whole window/guide assembly from the opening.
Offline 30below
« Reply #7 on: September 02, 2006 - 06:34:09 AM »
Thanks guys,got them out.
