Author Topic: Do you have your fender tags/ build sheet?  (Read 48376 times)
Re: Do you have your fender tags/ build sheet?
« Reply #105 on: October 19, 2016 - 09:42:46 PM »
Yep, found mine on top of the glove box.  Apparently it has ridden there it's whole life.  When I owned the car the first time ('79-'83) I had always thought the front left fender had been wrecked and replaced.  However, this sheet shows that the same fender was caught and replaced at the factory.  The fender has a white stenciled part number on the under side.
Would it be possible you can use an uploader website and show these again at 800 x 600?
I would like to see better details on these.
Offline PaxtonPwr
« Reply #106 on: April 06, 2017 - 04:10:30 PM »
Anyone able to decode, 8-69 production date on door sticker and here is tag and one of the sheets
Offline 1burgfish
  • These are troubling times
« Reply #107 on: August 24, 2017 - 11:06:02 AM »
 :working: I don't have either fender tag or Buildsheet;  I found my car in Puerto Rico and the only items on it was the door sticker and the VIN and the Dealer emblem where the car was originally sold. I tried looking up the dealer which was located in Florida and they no longer exists :faint: so I'm stuck like chuck...
Offline Beekeeper
« Reply #108 on: August 25, 2017 - 12:30:50 AM »
Photo is blurry but it looks like 8-22-69.
Offline BZaar
« Reply #109 on: January 26, 2021 - 05:21:25 PM »
I have my fender tags and 2 build sheets for my AAR Cuda - interesting that the build sheet I found under my back seat matched my VIN, but the build sheet I found behind the passenger seat back was for the next sequence number car.  So I'm guessing the guy on the line that day grabbed the wrong seat?
Offline BZaar
« Reply #110 on: July 22, 2021 - 02:48:13 PM »
If anybody knows somebody with a Fe5 red AAR Cuda - sequence #294245 - I have a very nice build sheet for your car, that I found in my Fe5 red/red AAR Cuda with the previous sequence number
« Last Edit: July 22, 2021 - 03:01:05 PM by BZaar »
Offline 'Cuda Hunter
  • Tastes Like Chicken
« Reply #111 on: December 29, 2022 - 01:03:51 AM »
Looks like the build sheet you have is for this car.
https://www.mecum.com/lots/FL0123-539315/1970-plymouth-aar-cuda/
They already have two build sheets.
I'd be interested in that build sheet if you want to let it go.
