The guy that hung the 1/4 skin should have trimmed that just after re spotting it to the outer wheelhouse. Then it gets finished with the body. You will want to cover that cut with paint asap. BTW, if you were only cuting thru one thickness of steel, you may want to take a good look at the rest of the job. That's supposed to be a double thick flange there between the wheelhouse and the skin.
