Author Topic: Voltmeter  (Read 1539 times)
nivvy
Voltmeter
« on: April 05, 2007 - 09:10:56 PM »
when you are driving your car how many volts should you be registering on the guage ??? mine was running at about 14 ???
Re: Voltmeter
« Reply #1 on: April 06, 2007 - 01:15:01 AM »
13.8-14.2
nivvy
Re: Voltmeter
« Reply #2 on: April 06, 2007 - 01:16:21 AM »
as always chyrco.. you da man...and my internet mechanic  :2thumbs:
Re: Voltmeter
« Reply #3 on: April 06, 2007 - 01:38:13 AM »
you are welcome  :2thumbs:
nivvy
Re: Voltmeter
« Reply #4 on: April 06, 2007 - 08:19:08 AM »
What should your voltmeter read at startup ??? mine is 11.5 ... I think thats to low ...Im gonna charge my car up and see if it starts ...
Offline quagmire
  • Traction Impaired......
Re: Voltmeter
« Reply #5 on: April 06, 2007 - 09:21:43 AM »
If the voltage is 12.6v or lower while running, the alternator is not charging and you are running off of the battery.
nivvy
Re: Voltmeter
« Reply #6 on: April 06, 2007 - 09:33:15 AM »
when the car is running it is almost 14... I was just curios what other people car was at start up ..
Offline ted
  • 74 cuda, 70 challenger r/t
Re: Voltmeter
« Reply #7 on: April 06, 2007 - 10:46:52 AM »
NORMAL.
Offline GoodysGotaCuda
Re: Voltmeter
« Reply #8 on: April 06, 2007 - 11:10:55 AM »
perfectly normal, mine is actually about 14.3 on the Cuda
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline blown74
  • Never go less then 60 MPH in Reverse! Bel Air, Md
Re: Voltmeter
« Reply #9 on: April 09, 2007 - 11:55:24 PM »
Make sure you use a good DVM when checking voltages. I once used a 25.00 dollar meter to check my boat batteries. Said I was charging them at 18 volts. I almost .... Checked with a good meter showed normal voltage. Remember you cranking voltage will vary some depending on motor compression, starter and even you wiring. On average I'm guessing it takes 250-400 amps  :wow:to start these v8's an even more in some cases. A high compression motor without a high torque starter starter pulls some serious juice. Thats when its warm. The numbers are worse the colder it gets.
American Muscle Rocks !!
