Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Interior and Gauges
(Moderator:
Chryco Psycho
Voltmeter Fluxuation
« previous
next »
Print
Pages: [
1
Author
Topic: Voltmeter Fluxuation (Read 962 times)
nivvy
Guest
on:
April 17, 2007 - 09:19:45 AM »
When I took the chally out last night around the block I noticed the voltmeter dropping and rising...yes I had the headlight on...
is this common
Logged
Grundy
Jr. Member
Re: Voltmeter Fluxuation
Reply #1 on:
April 17, 2007 - 10:08:00 AM »
Do you mean ammeter?
Logged
Drive it like you stole it.
Oldschool
Administrator
Permanent Resident
Member Since 9-05-06
Reply #2 on:
April 17, 2007 - 10:22:26 AM »
If it dropped at or near idle and then rose when the rpm's rose, that would be normal.....
Logged
Ken -- In Georgia
nivvy
Guest
Reply #3 on:
April 17, 2007 - 11:49:40 AM »
thx old's ... right as usual...
Logged
GoodysGotaCuda
Sr. Resident
Reply #4 on:
April 17, 2007 - 07:45:58 PM »
alternator output will vary by rpm. Usually low rpm (idle) will give out less current causing your amp gauge to drop and vary. It should seem to steady out as you hold the rpm up.
Logged
Build Page:
Goody's 'Cuda Build Page
1976 Dodge Warlock
Wheel & Tire Specs:
Link
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
Interior and Gauges
(Moderator:
Chryco Psycho
