Author Topic: Number 1 fuse?  (Read 720 times)
Offline Stacked440
Number 1 fuse?
« on: April 15, 2007 - 09:06:17 PM »
I have a short somewhere in my front harness, keep blowing fuses :crying:  But the fuse box only lists the fuse its blowing as "#1 fuse"  I looked through the shop service manual and nothing came from it.  Anyone know what all is powered through "Fuse 1"?
-Kyle-
Offline ShelbyDogg
Re: Number 1 fuse?
« Reply #1 on: April 16, 2007 - 01:40:15 PM »
Your Sig says 71.  What color wires come out of that fuse?  Unclip the fuse panel, with the 2 clips and turn it over to see the colors.   What doesn't work when that fuse blows?
Offline Oldschool
  • Member Since 9-05-06
Re: Number 1 fuse?
« Reply #2 on: April 16, 2007 - 05:26:34 PM »
Is the correct amp fuse in the "fuse #1" slot?  If it is too low for the load, it will blow pretty quickly....    :cooldancing:
Ken  --  In Georgia
Online Bullitt-
Re: Number 1 fuse?
« Reply #3 on: April 16, 2007 - 08:22:19 PM »
For what it's worth my '73 manual lists fuses in section 8, electrical, under specifications which is just before wiring diagrams. I would think that 71-73 are not very different. #1 fuse for the '73 is for brake warning lamp, oil pressure lamp(standard instruments), seat belt lamp, seat belt relay, and seat belt buzzer.
Offline Stacked440
Re: Number 1 fuse?
« Reply #4 on: April 16, 2007 - 11:19:39 PM »
Thanks bullitt, just what I needed to know :thumbsup:
-Kyle-
