Author Topic: Can the corrugated section of the steering column be removed?  (Read 800 times)
Offline jeryst
« on: April 27, 2007 - 10:05:20 PM »
I'm talking about the part behind the steering wheel, that looks like it is corrugated, or like an accordian. I've seen it referred to as a "steering extension" and I was wondering if it can be removed.
        :clueless:
The reason that I ask, is that my project 73 Cuda does not have one. The wheel is very close to the dash, and this peice is not there. At first I thought that maybe there is a different steering column in it, but I don't know what else will fit. Looks like it was made for someone with really long arms, or a gorilla. I will post  pics within the next couple of days when I can get up to the garage.
Also, does anyone know if a steering column from a 73 automatic will work in a 73 4-speed? I believe both are power steering.
Re: Can the corrugated section of the steering column be removed?
« Reply #1 on: April 27, 2007 - 10:08:16 PM »
Yeah, CODY did a whole thread on taking them apart and restoring.
Offline Carlwalski
« Reply #2 on: April 28, 2007 - 12:14:39 AM »
You're referring to the crush can and it can definitely be removed.
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
« Reply #3 on: April 28, 2007 - 01:53:02 AM »
The column will swap as long as both are power steering ,
