Hi, I'm wondering if anyone out there has experience welding over brass alloy
brazing? The quarter I want to replace with a new piece from Goodmark, was
replaced as an accident repair once before but instead of welding it in place
they brazed it. Will the contaminated metal cause me a problem like in the door
jam area where I'm forced to weld to used metal? Is there a proper way to clean
that up so I can get decent welds? I need to replace it due to rust and also they
cut it into the C-pillar very low, with a huge nasty overlap, from about the trunk
opening corner to the bottom back corner of the quarter window! From inside the trunk
it looks like...
Any suggestions would be welcome!! Jeff
