Author Topic: Removing wiper arms  (Read 1188 times)
Offline Travis72
Removing wiper arms
« on: June 16, 2007 - 04:07:37 PM »
Another question.... how do you remove the windshield wiper arms from the posts?  Is it as simple as prying up on them?
Thanks,
Travis
72 Cuda
Offline 422STROKER
  • Member Since 6/3/06
Re: Removing wiper arms
« Reply #1 on: June 16, 2007 - 04:11:49 PM »
There may be a little tab you have to pull out on , although that could be the B-body I had.   Try and get a towel under the thing you are prying with so you don't scratch the paint.  If you're getting ready for paint no as much of a worry.  I used a small(tiny 4" long) pry bar and they came off easy.  There is a tool for this though.
Good luck, sounds like you are getting ready for paint!
Tom :bigsmile:
Tom
Offline r15303
« Reply #2 on: June 17, 2007 - 08:48:12 AM »
Try pulling the wiper arms up and then lightly prying.  That should work.   :bigsmile:
« Reply #3 on: June 17, 2007 - 09:07:08 AM »
there is a tab under the arm to release it
