Author Topic: Who dares. - Calc. True Rear Wheel Horsepower ..???  (Read 751 times)
Offline cowboy
  • Denmark
    • CowboyCars.dk
« on: December 18, 2007 - 03:53:29 AM »
Got this side from another tread, and played around for a while...
http://www.wallaceracing.com/Calculators.htm
I'm a little down from what I expected....   :bricks1:
Flywheel HP:  603
Rear wheel HP: 543
0 to 60 time is: 2.27
I dare you, - You'r next...  ???    :roflsmiley:
« Last Edit: December 18, 2007 - 05:44:02 AM by cowboy »
Offline GoodysGotaCuda
Re: Who dares. - Calc. True Rear Wheel Horsepower ..???
« Reply #1 on: December 18, 2007 - 04:39:03 AM »
sayin 274rwhp for my 318  :dunno:
1976 Dodge Warlock
Wheel & Tire Specs:Link
nivvy
« Reply #2 on: December 18, 2007 - 05:49:44 AM »
numbers are definately different from that site ... :chatting:
« Last Edit: December 18, 2007 - 05:52:21 AM by StRoKer »
« Reply #3 on: December 18, 2007 - 07:03:33 AM »
They are making some assumptions with their formulas. Mine was 100 hp higher that actual.
For another shocker on your compression ratio, plug your engine specs into this. http://www.rbracing-rsr.com/comprAdvHD.htm
nivvy
« Reply #4 on: December 18, 2007 - 04:31:37 PM »
Its amazing how different they are.... I am really only worried about my timeslip but that is the formula used... however i guess if people use differen formulas for their website I guess it really is garbage in is garbage out!
« Reply #5 on: December 18, 2007 - 05:04:25 PM »
True. In my case I operate at a physical altitude of 6000 ft. Occasionally weather conditions can put it as high as 10,000 ft.  Unless a calculator has some provision to allow me to manipulate the air density via altitude, it is pretty worthless to me.
Of course, I've never run my car in perfect air at sea level. Chances are it could have 100 extra horses in those conditions.
