Author Topic: 3spd Wiper motor  (Read 1249 times)
3spd Wiper motor
« on: February 06, 2010 - 07:32:17 PM »
I have a 3sp/variable wiper motor with the number
3431780
 73692
  2725
on the motor casing. I realize the 'park' is different for different models, so how can I tell if it will work in my Challenger?
Offline swede-cuda
Re: 3spd Wiper motor
« Reply #1 on: February 06, 2010 - 07:43:03 PM »
 :wave:in the service manual there should be a drawing that shows which slot an e-body contact lid should be set in.there is a tang on the lid that goes in 3? different positions.i dont remember witch or if it will work in an e body,whats it from?if the little linkage on the back is the right one for your car ,then maybe it will work.
Offline passion4mopars
    • Passion4mopars
« Reply #2 on: February 06, 2010 - 09:46:21 PM »
Just below the housing ear opposite the ground strap.  The first knotch past the flat is E body timing, the "C" is for C body park timing and below the "C" is B body park timing    :angelwings:
3431780  is a C body wiper motor  3 speed
Your date code is 272nd day of 75 on the cylinder
A "C" body bulkhead clip has the index on the opposite side than an E body bulkhead clip also.  It can be made to work for your car.  Change the timing and change the bulkhead connector.
« Last Edit: February 06, 2010 - 09:52:24 PM by passion4mopars »
« Reply #3 on: February 07, 2010 - 06:16:02 AM »
Thanks for the excellent info! :2thumbs:
    • Passion4mopars
« Reply #4 on: February 08, 2010 - 07:12:25 PM »
http://www.passion4mopars.com/pages/wmpn
That info might be helpful....It's an accumulated list of wiper motor part numbers and applications    :bananasmi
