Author Topic: Automatic pistol grip install  (Read 618 times)
Offline HemiOrange70
« on: May 14, 2010 - 11:56:18 PM »
I have restoricks pistol grip for automatics. ANyone have one and how did it install?
Thanks
Re: Automatic pistol grip install
« Reply #1 on: May 15, 2010 - 11:34:59 AM »
I installed a 71 a couple of weeks ago , it had a small set screw to hold it on the 70 style would be  differentbut probably held on with a small set screw as well
« Reply #2 on: May 15, 2010 - 11:45:46 PM »
So the set screw titghtens agaisnt the threaded stem?
« Reply #3 on: May 16, 2010 - 05:46:48 AM »
no , the set screw should tighten on the stem below the threaded inner stem
« Reply #4 on: May 17, 2010 - 11:27:48 AM »
My set screw will not go down far enough :swear:
