Author Topic: Isn't anything made in America anymore???  (Read 4944 times)
Offline Road_Runner
Re: Isn't anything made in America anymore???
« Reply #15 on: May 31, 2010 - 12:05:14 AM »
is it not possible to run headers on a BB with a normal starter...?
  You sure can, I did it for years with Hooker Super Comps on my big block Roadrunner.  I went with Mopar Performance mini starters on both of my cars mainly for extra clearance plus they spin the engines faster for easier starts.  Before mini starters I could always tell a Mopar before it fired up just by the distinctive (& slow) way the stock starters turned over the big Mopar engines.  They worked fine, but if you ever have to take it back out you'll be happier if you went with a mini.
Later, Jim
1970 383 Roadrunner Tor Red
1973 318 Barracuda Mist Green
Offline dutch
« Reply #16 on: May 31, 2010 - 06:03:00 AM »
ok,
so do starters from let`s say, a `95 voyager v6, bolt right into a BB or does it need to be altered...?
*** Bart ***
Offline the_engineers
« Reply #17 on: May 31, 2010 - 10:21:07 AM »
American flags aren't made in America anymore... :walkaway:
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
« Reply #18 on: May 31, 2010 - 10:29:43 AM »
You can get one from my home town
http://www.alabamaflag.com/
« Reply #19 on: May 31, 2010 - 12:23:56 PM »
ok,
yes, the typically bolt right in, but, since most late model cars have a large integrated wire harness connection, some starters require a bit of tweaking to the battery cable connection to avoid hitting the block.
« Reply #20 on: May 31, 2010 - 07:37:33 PM »
You sure about that?...Bolt Pattern in pictures sure do look different for the FWD vs RWD
RWD pickup/van
FWD mini van
Classic
« Last Edit: May 31, 2010 - 07:40:12 PM by Bullitt- »
Offline 70_challenger
  • Suburban Detroit, Michigan
« Reply #21 on: May 31, 2010 - 11:27:34 PM »
Guys:
Look at the post by BIGSHCLUNK.  That unit it made by a company that I am VERY familiar with (nudge, nudge, wink, wink).
Many of the Mopar Performance starters, and quite a few of the Chrysler factory starters (especially from trucks) look like that one.  Darn good quality starters, and you can get them from our pal Dave at Roseville Chrysler.  That is the starter you want - And notice where it is made!
-Tom
« Last Edit: May 31, 2010 - 11:29:21 PM by 70_challenger »
« Reply #22 on: June 01, 2010 - 08:41:29 AM »
No, but I do know any of the 5.2 and 5.9 units interchange perfectly with big block units. Since the 3.9 V6 is a 5.2 with two cylinders lopped off, it should work as well. Any of the Mitsu V6, I wouldn't know for certain.
« Reply #23 on: June 01, 2010 - 09:13:05 AM »
The '95 front wheel drive mini van is none of the above....3.0, 3.8, & 3.3(most common) and are not on the LA platform..
Offline JoltinJoe
  • BALZ TO THE WALZ MAN
« Reply #24 on: June 03, 2010 - 09:44:28 PM »
 :2cents: If your having starter clearance problems, you can get one of those adjustable ones.   :2cents:
HIS: '68 GMC 3/4 ton pick-up truck, '73 Barracuda, '87 Firebird, '01 Jeep Cherokee and finally a '70 Barracuda Convertible!
HERS: 1980 Toyota Starlet, 1995 SAAB 9-5 and then '01 SAAB 9-3 and currently '08 Saab 9-3 convertible!
NEXT IS MINE: purple 2010 Dodge Challenger!!!
Offline acudanut
« Reply #25 on: June 05, 2010 - 10:05:59 AM »
 This topic is waay off course.
Offline hpe600rt
  • how sweet it is
« Reply #26 on: June 05, 2010 - 11:18:59 AM »
i think they make the things cheaper so you have to keep buying moure and they get rich
Offline heminut
« Reply #27 on: June 05, 2010 - 12:28:25 PM »
The mini starters from the front wheel drive minivans WILL NOT work on the V-8's, they have a different snout and won't bolt up.
1970 5.7 Hemi Cuda
Offline dwbiggs
« Reply #28 on: June 09, 2010 - 04:37:25 PM »
Was at Carlisle and happened to look at a set of Foose wheels and lo and behold, on back was a big " Made in China" stamp.  For some reason I figured Foose wheels would be made in America.
Offline acudanut
« Reply #29 on: June 11, 2010 - 10:02:26 AM »
Foose is half Chinese from the Getto>>>Look at some of the Getto style cars he has made.
