Author Topic: SHaker fitment: Shared experience  (Read 686 times)
Offline DocMel
« on: June 18, 2010 - 06:21:27 AM »
I have seen allot of posts  WHat carb will fit a stock type shaker, manifold etc
Ill tell you what fit mine:   Realize there are many variables:  Moldings of the various shaer repops, types of intake manifold, type of hood (steel or fiberglass), type/condition of motor mounts, you name it, etc.
I'm running a stock 440 , AVS E brock carb, orignal 440 intake maniold  (4 barrell) of a 1970 440, one inch Summit carb spacer.  Engine mounts are stock type, fiberglass hood, shaker repop kit form pentastar repos
Bottom line:  THe fitment is PERFECT:  I had expected it to be too loose or tight against the hood opening: The shaker seal fits snug against the hood when closed.  Not too tight, not loose
Offline mopardave
  • Sponsor
    • rosevillemoparts
Re: SHaker fitment: Shared experience
« Reply #1 on: June 18, 2010 - 08:28:41 AM »
AVS style is the only carb that works well with out modifying the base plate for the holley or proform.
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
