Author Topic: turn signal flasher  (Read 755 times)
Offline Cudaah
turn signal flasher
« on: July 12, 2010 - 02:06:04 PM »
I was in the process of replacing my flashers on my car and noticed the one on the steering column is square and the one by the ashtray is plastic colored light blue.  I replaced the one by the ashtray with a new one from advance and then nothing works.  Is there a specific flasher that I need?  Or should I try the electronic ones?
« Last Edit: July 12, 2010 - 02:08:03 PM by Cudaah »
Offline ShelbyDogg
Re: turn signal flasher
« Reply #1 on: July 13, 2010 - 09:57:36 AM »
You can get the electronic ones to replace the thermal ones but you won't get the hanging blinker when you lose a brake light or front turn signal bulb.  Also, if you put a quiet one in, instead of a noisy-clicky one, you wont hear it clicking loudly to remind you that the signal is still on.  Thermal ones are rated by load for number of bulbs controlled.
Electronic ones will work with a timed flash not caring of you have 3 or 6 bulbs so they are a better flasher.
Square or round, a flasher is a flasher.
