Author Topic: what to look for in a coil and plug wires?  (Read 826 times)
Offline black71
  • eph 6:12
« on: July 23, 2010 - 08:36:49 PM »
cruisin summitt racing and was just wondering what to look for in a coil (primary resistance) and same with plug wires??
Offline black71
  • eph 6:12
Re: what to look for in a coil and plug wires?
« Reply #1 on: July 23, 2010 - 08:38:01 PM »
also looking at msd ignition boxes and wonder how these play a role in choosing a coil and plug wires
Offline 422STROKER
  • Member Since 6/3/06
« Reply #2 on: July 23, 2010 - 09:39:15 PM »
Biggest thing is a set of wires that will fit with your setup, either with or without headers.  I'd guess that the coil will have to be chosen after you decide either MSD or not.
Tom
I run MSD 6AL and MSD coil along with their wires,  works for me.
Tom
« Reply #3 on: July 24, 2010 - 02:51:51 AM »
solid core wires cause electronic interference , I use a good quality spiral core wire Such as Firecore , MSD or Blue Max
Offline 73EStroker
« Reply #4 on: July 25, 2010 - 08:55:05 PM »
Boils down to personal choice as they are all about the same for reliability and performance. I chose Mallory distributor, Mallory Digital 6 box and high output Mallory coil and MSD 8mm wires. They work together great and no ballast resistor required. The Mallory digital box has an adjustable rev limiter standard on it. Then my son runs a MSD box, distributor and coil on his 440 and his car runs flawlessly.
Barry (Salmon Arm)
Offline wally426ci
    • maryland mopars
« Reply #5 on: July 26, 2010 - 09:45:53 AM »
Look for the name MSD on the wires, can't go wrong. They even have the same colors as some NOS mopar wires i've seen.  :wave:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
