Author Topic: help me with direction were to go with my 340  (Read 1560 times)
Offline Justins72
« on: September 20, 2010 - 10:31:30 AM »
Sometime in the next im going to be pulling my 340 out of the car for a winter project.  Right now I know the motor isn't stock but I dont know who built or whats in it. What I want to do is build a motor that has decent power but also reliable.  The car will never see the track and raced, Its a car show car that I would like to drive it to the show other then towing it. It will be backed by a 727 auto but hopfully will have an overdrive auto when its time to install it back into the car.
Now I have a list of what was done to the engine but the people that owned it before my grandfather intended it would be a drag car but I was told he also didnt know what he was doing when he built the motor. So Im going to be starting over with hopefully the help from the CC crowd.
Right now the motor has been bored .030 over. The heads have been ported and bigger valves, From what I have heard they flowed really good too. So I will be getting them flow tested and see if they are not too much for what I want from the engine.  I have also been looking into aluminum heads as well though, more exact the Edelbrock Performer RPM aluminum heads or if anyone has something that better let me know. For compression ratio I want to run 91 pump gas so im looking at 9.5:1- 11.5:1 depending on if i go with iron or aluminum heads.  For camshaft I have no Idea on were to start looking, since it will be a street/highway cruiser I dont want to powerband too high up there in the rpm's. Same with the manifold since it would need the powerband to match the cam. Right now it has an LD340 intake on it. Also one thing I should mention is that I do not want to stroke the motor.
Re: help me with direction were to go with my 340
« Reply #1 on: September 20, 2010 - 12:57:02 PM »
the heads will be fine , Iron will keep more heat in the combustion chamber , the LD340 intake is one of the best ever , the only upgrade might be the RPM Air Gap intake , the cam needs to be matched to the intake & converter if auto is used , I would be looking into the Lunati Voodoo line for cam choice
Offline Justins72
« Reply #2 on: September 20, 2010 - 01:48:06 PM »
Are you talking about the stock iron heads or the aluminum edelbrocks? Also what is the rpm range for the LD340 intake? Once the motor is done I will get a stall converter to match.
« Reply #3 on: September 20, 2010 - 09:03:03 PM »
I was talking about the Iron heads , they will be adequate for what you are doing . I do not feel the alum Eddys are worth the extra cost , the LD340 is good for about 1800 - 6000
Offline Justins72
« Reply #4 on: September 22, 2010 - 11:13:03 AM »
I was able to find the piece of paper that had a list of what was done to my motor.  Now If this is whats really in it, I dont know for sure.
Manifold: LD340 and 1 inch spacer
Carb: 3310-2 holley 750cfm (wasnt on the car when got it now 750 Demon)
Distributor: Electronic accel parts
Coil: Accel super coil (Now MSD Blaster 2)
Lifters: ISKY anti pump up 3002
Push Rods: Norris Adjustable
Cam: Howard Racing 310 280 dur  465 Lift (thats the only spec i got on it)
Timing set: Cloyes True Roller
Cam Bearings: Clevite
Crankshaft: (custom), Balanced, Forged, and Shot peened. Also says something  about chromoly journals polished, chambered oil passages?
Pistons: Speed pro .030 no2332
Connecting rods: Balanced, shot peened
Main Bearings: TRW clevite 77
Rod Bearings: TRW clevite 77 (CB481P)
Oil Pump: High Volume Direct Connection
Rings: Racing Custome
Oil Pan: Chrome 5qt
Connecting rod bolts: Direct connection High Strenght
Heads: 360 port matched, polished
Valves: Speed Pro 2.02int 1.65exh
Fuel Pump: electric Mallory
Retainers: Norris Titanium
Valve Springs: Isky
Valve Guides: Bronze walled.
Also Have some numbers on the back of the paper but I dont know what they mean except for the VIN number.
Head ID #1611
Block ID # 5630  31210257
Vin# JS23H2b20****
« Reply #5 on: September 22, 2010 - 11:18:41 AM »
the cam is extremely long duration & with no lift to boot , looks like a stock cheater cam of some sort
I would swap the cam to a 235* @ .050 with about .520 lift for street use , Check into Lunati VooDoo cams
Offline Justins72
« Reply #6 on: September 22, 2010 - 12:29:19 PM »
So can the cam that says it has in it be a reason why the car feels like it has no power to it? Also any Idea what the ID numbers mean?
Offline Justins72
« Reply #7 on: September 22, 2010 - 12:32:14 PM »
Okay I was looking through lunatis voodoo cams and came across this. Looking at the RPM range will it be too much for the LD340 intake?
 Voodoo Hyd Cam Kit - Chrysler 273-360 276/284
Hydraulic. Hot Street cam, likes 2800 converter, Hi-Rise type dual plane intake with 750cfm carb, headers, 10:1 compression and 3.73 gears. Likes up to 200HP nitrous.
    * Advertised Duration (Int/Exh): 276/284
    * Duration @ .050 (Int/Exh): 234/242
    * Gross Valve Lift (Int/Exh): .513/.533
    * LSA/ICL: 110/106
    * Valve Lash (Int/Exh): Hyd/Hyd
    * RPM Range: 2200-6400
    * Includes: Cam Kit
« Reply #8 on: September 23, 2010 - 01:14:24 AM »
That cam would work or you could go 1 lower dependign what you want the engine to do , what stall do you intend to use & do you know what gaers are in the diff ??
with the cam that is in the engine now it should have power but not until you are into the 3000-3500 range
Offline Justins72
« Reply #9 on: September 23, 2010 - 10:53:30 AM »
Not sure what gears are in the rear end but I do know that I was cruising on the free at about 3500rpm at 60 mph.  The power band range you gave on the cam sounds about right which is why it feels sluggish on the bottom end. I definitely want to bring the power band down into 1000 1500 range. Im not sure on the stall yet but I don't want a too high of a stall converter, im thinking somewhere between the 2400-3000 range. But like i said it will be driven on the street/highway.
« Reply #10 on: September 23, 2010 - 06:32:43 PM »
I would look at the cam you found with a 2200 stall , you probably have 391 gears
