Author Topic: What is the proper way to ground your fuel sending unit  (Read 6643 times)
Offline 70 RAG TOP
« on: April 29, 2012 - 04:09:55 PM »
I am having problems with my fuel gauge working properly(yes I know all too well about the issues Chrysler had with the fuel gauges).  My question is, what parts are required for grounding purposes?  The strap type ground (the flat one with gripper jaws on each end that bridges from the sending unit to the hard main fuel line)seemed to be a weak link, so I  instead used a short piece of heavy gauge stranded wire and used clamps to hold the wire against the fuel lines.  But I am still having intermittent  functioning of the gauge.
When the tank is full, the gauge only reads about 1/2.  Could this be remedied by pulling the needle loose and putting it back on with needle pointing at full(when the  tank is full)?    My sending unit is fairly new and in good shape I think.   Any thoughts
Re: What is the proper way to ground your fuel sending unit
« Reply #1 on: April 29, 2012 - 04:25:54 PM »
What do you mean by intermittent?
If your gauge is reading half full when it's full, I think your sending unit is junk like most after-market units.
Offline usraptr
« Reply #2 on: April 29, 2012 - 05:08:28 PM »
 :popcorn: :popcorn:
(Edited 8-1-17)
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« Reply #3 on: April 29, 2012 - 10:56:43 PM »
I had a similar fuel guage reading issue.  A full tank would read half and sometimes empty.  It was not the ground or the sending unit.  It was my float.  It had a small fracture which let fuel enter into it.  The float basically became an anchor and was sinking to the bottom of the tank giving an empty reading when indeed it was full.  Check your float!
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
Offline dutch
« Reply #4 on: April 30, 2012 - 08:30:30 AM »
       :iagree:   float 2x
*** Bart ***
Offline JayBee
« Reply #5 on: April 30, 2012 - 08:50:28 AM »
 :iagree: 3x  Eventually my float filled enough where the readings were no longer intermittent, just empty. I did the clamp/wire thing also, to no avail,  after that is when I found the float had gas in it. .
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline GoodysGotaCuda
« Reply #6 on: April 30, 2012 - 08:57:21 AM »
If  I remember right, I took that "jaw" clamp and ended up soldering a wire to it. Then took that wire to a known good ground.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline Barracudadan
« Reply #7 on: April 30, 2012 - 10:24:47 AM »
If I had to guess I would say your problem is somewhere in the sending unit or the float. Don`t mess with the needle on the gauge! Try searching the archives lots of good suggestions there to get them working properly. I got my original working again with some of those tips. The thin wire soldered to the float swing arm was a good tip to improve grounding problems.
Offline JayBee
« Reply #8 on: April 30, 2012 - 03:44:01 PM »
Page 2 and page 4 show the "swing arm wire".
http://www.cuda-challenger.com/cc/index.php?topic=67680.45
John
2014 Toyota Avalon
Offline Matt70
« Reply #9 on: April 30, 2012 - 08:38:51 PM »
Did it to mine fuel gauge has worked great since   :2thumbs:
People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf.
George Orwell
Offline 70 RAG TOP
« Reply #10 on: May 03, 2012 - 10:44:49 PM »
Thanks for your replies and your links to other threads.  Going to try the wire/solder method!
Hope it works!
