Author Topic: Speedometer Cable Retainer/Clip?  (Read 1381 times)
Offline filmsurgeon
  • Resto-Mod '70 Convertible Challenger
« on: January 09, 2014 - 03:01:57 AM »
Does anyone know if this speedometer cable retainer/clip is being reproduced?  If so, where can I get one/who has them?  If not reproduced, what (if anything) have you guys done?  Is there a suitable alternative that's both effective, and "not-too-cheesy"?  Thanks.
1970 Challenger Convertible (JH27N0B); Resto-Mod; 605 HP, 412cid Small Block; Holley 750CFM Carburetor; A-833 23-spline 4-SPD; A-body 8.75 rear-end w/3.55 gears; 3" mini-tub; leaf spring relocation kit with split-leaf mono and Caltracs; American Racing AR500 Wheels, Rears = 15x10 (5.5" BS) with 315/60-15 BFG Comp T/A Drag Radials; Fronts = 15x7 (3.5" BS) with 215/70-15 BFG Radial T/A Radials.
Re: Speedometer Cable Retainer/Clip?
« Reply #1 on: January 09, 2014 - 09:50:10 AM »
I thought my speedo cable came up through the center of that bracket...not on the side of it. :clueless:
Offline Katfish
  • 70 Challenger
« Reply #2 on: January 09, 2014 - 10:30:07 AM »
I used a zip tie, sorta cheesy, but easy and effectve.
Offline anlauto
« Reply #3 on: January 09, 2014 - 10:34:19 AM »
No...He's right it does come up on the leftside of the pedal bracket. Don't think the clip is being reproduced.
Maybe an B Body Air Grabber hose retainer clip will do the job....They look nothing like it, but will retain the cable :dunno:
Offline anlauto
« Reply #4 on: January 09, 2014 - 10:36:38 AM »
Get your mind out of the gutter...........A Body gutter that is ! :smilielol:
« Reply #5 on: January 09, 2014 - 11:04:21 AM »
I know I ran mine through the center.  I'll have to check it out in the spring. I'm surprised I was able to get it hooked up that way.
Offline filmsurgeon
« Reply #6 on: January 09, 2014 - 11:52:58 AM »
I'm fairly certain that the correct cable routing should be along the left side of the pedal assembly, but here's a photo (showing the same clip/retainer) with the cable running up through the center of the pedal assembly.
« Last Edit: January 09, 2014 - 11:54:42 AM by filmsurgeon »
Offline anlauto
« Reply #7 on: January 09, 2014 - 01:29:13 PM »
That's incorrect
