Author Topic: Clutch Free Play: Adjusted out, Pedal Still Low  (Read 2891 times)
Re: Clutch Free Play: Adjusted out, Pedal Still Low
« Reply #15 on: March 16, 2014 - 07:56:10 AM »
I used to get spares all the time from the wreckers & always had a few longer ones , the dodge trucks have longer ones as well of course all my spares are where now ???
Offline 73EStroker
« Reply #16 on: March 17, 2014 - 02:15:26 PM »
You also require a large diameter flat washer between the adjusting nut and the rubber on the bellcrank side. And you only require the locking nut on the bellcrank side. Turf the other one and is that adjuster nut on backwards. Flat side should sit against the missing washer. That will take a bit of spongy feel out of the clutch pedal movement.
Barry (Salmon Arm)
« Reply #17 on: March 17, 2014 - 06:53:18 PM »
He is running the steel ball pivot used on the trucks
« Reply #18 on: April 05, 2014 - 10:17:19 PM »
looks like you need a longer adjuster rod from a different application
Put in the longer A body rod today.
It worked.
Still a mystery why I needed just a few more threads out to get the pedal freeplay right.
Offline Sleepychallenger
« Reply #19 on: April 06, 2014 - 12:10:20 AM »
Will it cause problems if the longer rod isnt used?
« Reply #20 on: April 06, 2014 - 07:38:32 AM »
the finger height on the clutch pressure plate may not be the same as factory , yes it will cause problems using the shorter rod , the clutch may never full release causing it to drag making it much harder to shift etc
