Author Topic: Road lamp switch (Where does it mount??)  (Read 2515 times)
Offline 440six
  • I Luv E-Bodies
« on: May 16, 2002 - 08:04:10 PM »
Hi, this should be a easy question for you guys, I am installing a road lamp switch in a 71 cuda and would like to know where it should be installed. My owners manual says under the wood grain switch bezel but I don't think so, as there is no place to mount it and drilling holes is not a option. Would appeciate any help,
thanks
« Last Edit: December 31, 1969 - 07:00:00 PM by 1023595200 »
Offline heminut
Re: Road lamp switch (Where does it mount??)
« Reply #1 on: May 18, 2002 - 10:03:26 PM »
The owner's manual is correct. If you car didn't originally come with roadlamps there will not be a hole there, but if you want to mount it the way the factory did, you'll have to drill a hole. If that's not an option, then you can put it wherever you want, but it won't look stock.
1970 5.7 Hemi Cuda
