Author Topic: Help Identifying 383 Longblock!  (Read 4100 times)
Offline Despicable Z
  • Mopar Newb
« on: July 06, 2014 - 03:50:36 PM »
Hey everyone! Mopar Newb in need of some help here. So I recently brought home a 70 Cuda (VIN: BS23N0B425413) and what I was told was a 440 longblock. The car was originally a 383 auto car but the stock motor and tranny were long gone. The seller knew little about the "440" motor- other than the person he bought the car from provided it, saying it was a 440 that they planned to one day drop in the car. Well I started looking over the motor last night and much to my surprise...I believe it is in fact a date correct 383 longblock.
Now I don't know squat about Mopar motors- but here are some of the block markings I was able to find:
Near distributor:
E 383
2 18 2
R
On the passenger side:
2468130  8
N D
On the driver side:
12 16 68
Regrettably- the patch on the passenger side oil pan rail looks blank to me- I can't see any sign of inscription at all.  When I saw E 383, and the 2468130 on the side I was getting REALLY excited thinking this might have been the matching #s 383 block from the car and the seller didn't even know it- but the lack of any VIN stamped on the side makes me think this might be a replacement motor?  Does having a date-correct replacement 383 make the car any more valuable than throwing in an aftermarket 440,  etc.. or is it sort of a wash? Thanks for any info on this motor you guys can provide! Anything else I should look for? Here's a few pics:
Thanks folks!  :cheers:
1970 'Cuda Project
1969 428CJ Mach 1 Mustang
2008 Corvette Z06 (Heads, Cam, Etc.)
2003 Mustang GT
Offline 1 Wild R/T
Re: Help Identifying 383 Longblock!
« Reply #1 on: July 06, 2014 - 04:18:12 PM »
E is a 69 engine
F would be a 70..
Should have an HP stamping if the car is an N code Cuda
End of the day it's a good engine to build as it will use the same block, crank & rods as the correct engine... A set of closed chamber heads (516's or better yet 915's) would help it quite a bit..
« Reply #2 on: July 06, 2014 - 07:56:12 PM »
12-16-68 & E would be correct for a march built 69 but is probably a replacement with no VIN stamp
  • Mopar Newb
« Reply #3 on: July 06, 2014 - 09:29:24 PM »
That's sort of what I was thinking guys! Bummer- got so excited when I saw 383  :crying:
Thanks for the information...time to weigh some rebuild options!
1970 'Cuda Project
2003 Mustang GT
Offline 1 Wild R/T
« Reply #4 on: July 06, 2014 - 10:23:28 PM »
« Reply #5 on: July 06, 2014 - 10:48:34 PM »
I agree except you cannot get 451 in a 383 block , with the smaller bore you end up around 436
Offline 1 Wild R/T
« Reply #6 on: July 06, 2014 - 11:17:31 PM »
Your assuming I would keep the 383 block... And you could but the bigger bore on the 400 helps with breathing...  Then again he has the 383 & it would be plenty for most guys as a street build..
« Reply #7 on: July 08, 2014 - 01:44:50 AM »
Sky is the limit
 stock block you can get close to 500 " in a 400 block 440 can be pushed closer to 550 & use a world block you can go to 5" bore & close to 600 CI
Offline Sleepychallenger
« Reply #8 on: July 08, 2014 - 07:36:48 AM »
Do a 383 to 496 stroker  :naughty:
  • Mopar Newb
« Reply #9 on: July 10, 2014 - 06:09:01 PM »
Sky is the limit
I like the way you think Chryco! I think I'm going to rebuild the 383 myself with mostly stock or near stock components as a back-up motor for the car, and splurge on a 440 stroker for the car. I really like the 505 & 520 shortblocks from MMR http://www.musclemotorsracing.com/short-blocks/big-block-stroker-short-block.html
Should be pretty easy to hit that 600hp mark with some MW heads and a good bumpstick I'd think.
1970 'Cuda Project
2003 Mustang GT
