Author Topic: Heater hose by-pass/shut off ?  (Read 1511 times)
Offline Racer57
« on: July 06, 2014 - 05:11:35 PM »
70 Cuda 383
Car gets too damn hot inside and need to shut off the heater. Whats a good quality by-pass or shut off for the heater hoses ? Almost bought a water valve from Ace. It would look like hell, but it would work.
Offline crash340
Re: Heater hose by-pass/shut off ?
« Reply #1 on: July 07, 2014 - 04:35:51 AM »
 :popcorn:
same problem here
Greg
73 Cuda
Brisbane, Australia
« Reply #2 on: July 07, 2014 - 10:22:08 AM »
is the heater door working properly inside the heater box , it should seal off any air coming through the heater core ,  the older dodge trucks in the 70s used a cable operated valve in the heater hose , you could look for one of those .
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #3 on: July 07, 2014 - 10:24:41 AM »
I could not find one so I bought a brass ball valve at home depot.  My hose is 5/8" and no one seems to make one that size so I went with a 1/2" with the brass barb fittings 5/8" down to 1/2" to adapt.  I flipped the lever facing down to hide it. Not the prettiest thing but it works!
Offline Racer57
« Reply #4 on: July 07, 2014 - 10:57:36 AM »
That's what I had thought of and might do. I'd also thought about painting it black and getting some black shrink tubing so that it wouldn't be quite as noticeable.
Offline 1 Wild R/T
« Reply #5 on: July 16, 2014 - 12:12:45 PM »
http://www.amazon.com/Four-Seasons-74828-Heater-Valve/dp/B001B7BUAU/ref=zg_bs_15723841_8
And a standard cable under the dash & you can turn the heat on/off from the drivers seat...
Offline HP_Cuda
  • Mopar or No Car!
« Reply #6 on: July 16, 2014 - 01:33:14 PM »
Grab some larger hose, cut it down the middle and slide it over your valve will hide it even more.
Offline 6771plymouth
  • john
« Reply #7 on: August 22, 2014 - 03:51:01 PM »
 I like that
Offline blown motor
« Reply #8 on: August 23, 2014 - 08:04:11 AM »
The AC cars had a shutoff that mounted on the right wheel well. It's controlled by a cable from the temperature contol on the dash. I can post a pic if you want.
