Author Topic: Themoquad carb idle question.  (Read 1439 times)
Offline woody9512
  • 71 Billboard Cuda, Pistol Grip 4-speed.
« on: July 06, 2014 - 06:53:42 PM »
My 71 340 4-speed Cuda idles great at start up but when its warmed up it idles a bit fast and I just want to turn it down. Has original TQ Carb.
My question is which screw do I turn once engine is warmed up to turn idle down a  bit and which way do I turn it.
A pic of the exact screw would be great as I think there are a couple of idle screws identified in the book I have for fast Idle.
As always thanks and much appreciated.
Tim
Re: Themoquad carb idle question.
« Reply #1 on: July 06, 2014 - 07:21:07 PM »
On my '73 there are 3-adjustments originally ... does yours still have a functional idle stop solenoid on the right side?
That is where the final idle adjustment was originally made, mine was removed long ago so I rely on the small screw on the left for warm idle & of course the big ole fast idle screw that rides on the fast idle cam for fast idle. Left turn lowers Right turn raises RPMs
 If your mixture screws are out to far (lean) you won't be able to get idle low enough. If that doesn't solve it then could be your timing.
« Last Edit: July 06, 2014 - 07:24:46 PM by Bullitt- »
Offline woody9512
« Reply #2 on: July 06, 2014 - 07:39:50 PM »
Attached pic of mine. Hopefully it came out ok.
Car runs great and like I say just idles but fast once warm.   I want to see if I can just turn the correct screw to turn down a bit. Like I said idles great at start up.
Tim
Offline cudabob496
« Reply #3 on: July 06, 2014 - 07:43:25 PM »
sometimes a vacuum leak can create a fast idle
2011 Kawasaki Z1000
« Reply #4 on: July 06, 2014 - 08:09:29 PM »
 :smokin: ... Clean looking Thermoquad
Offline woody9512
« Reply #5 on: July 08, 2014 - 10:44:09 AM »
Got it adjusted ok now I think :cooldancing:
thanks!!
Offline Rich G
« Reply #6 on: July 09, 2014 - 09:21:13 AM »
Make sure the fast idle cam isn't hanging up. It should not touch the fast idle screw when the choke is all the way open. That's the one below your pic.
