Author Topic: Spark plugs for MSD setup  (Read 712 times)
Offline LukeSkywalker
  • Plymouth
« on: July 07, 2014 - 09:55:21 AM »
I've got the MSD 6 Digital Plus box, Blaster 2 coil, ProComp distributor and have unmodified RJ12YC spark plugs in a fairly stock 440 engine.
Should this work as it stands? Should I change to different plug or should I open them up ?
A guy told me I might need different plugs for that setup, so I've done a search, and found this
MSD Digital 6 Plus :
Compression Spark Plug Gap
Up to 10.5:1: 0.050" - 0.060"
10.5:1 - 13.0:1: 0.040" - 0.050"
Above 13.0:1: 0.035" - 0.045"
And this tells me exactly nothing because I don't know what compression is in mine..
« Last Edit: July 07, 2014 - 09:58:08 AM by LukeSkywalker »
Re: Spark plugs for MSD setup
« Reply #1 on: July 07, 2014 - 10:02:31 AM »
I would set it at .040 - .045 using the plugs you have
  • Plymouth
« Reply #2 on: July 07, 2014 - 10:14:41 AM »
Thanks  :worshippy
Offline Bart
« Reply #3 on: July 07, 2014 - 11:00:41 AM »
I can see what I'm running tonight, have a 383 Indy heads MSD, but I think I had to gap about .050
Regards
1970 Cuda 383
2008 Titan
2010 G37s
1996 Advantage Victory 27 502ci
2013 HD Roadking
