Author Topic: Oil Sending unit thread size.  (Read 841 times)
Offline 74 challenge
« on: July 08, 2014 - 07:44:18 AM »
I am chansing a leak and thanks to an idea from Chryco i'm looking at my mechanical oil guage as a possible culprit. What is the thread size of the oil sending unit hole? I am planning on capping it and seeing if it still leaks.
Size? NPT?
Thanks!
1-8-4-3-6-5-7-2
Re: Oil Sending unit thread size.
« Reply #1 on: July 08, 2014 - 07:52:25 AM »
NAPA shows as  1/8" X 27 NPT
« Reply #2 on: July 08, 2014 - 08:04:26 AM »
Thanks! that is an odd size.
1-8-4-3-6-5-7-2
« Reply #3 on: July 08, 2014 - 08:28:39 AM »
quick search revealed it's the same size as some grease fittings
Offline GoodysGotaCuda
« Reply #4 on: July 08, 2014 - 08:29:52 AM »
Shouldn't be hard to find a plug at lowes or napa.
1976 Dodge Warlock
Wheel & Tire Specs:Link
« Reply #5 on: July 08, 2014 - 08:32:58 AM »
I am likely to change the guage if it's the reason for the oil leak so i am going to just use one of these form homedepot to check. It only needs to be in the engine for 20 minutes.
http://www.homedepot.ca/product/square-head-plug-1-8/924627
1-8-4-3-6-5-7-2
« Reply #6 on: July 08, 2014 - 10:05:11 AM »
That is the correct size , it is 1/8" pipe tread so it is a tapered thread . common fitting size
