Author Topic: Anybody run Cal Tracs Springs?  (Read 2075 times)
Offline RCCDrew
« on: July 08, 2014 - 03:13:27 PM »
Just wondering if anyone has experience with them on e bodies? I was thinking about their pros and cons. Definitely a lighter spring for sure.
Offline challengerx
Re: Anybody run Cal Tracs Springs?
« Reply #1 on: July 08, 2014 - 06:12:26 PM »
I run cal tracs and love them. I bought the 0 ride height and use there shocks also. I switched from mopar super stock springs and like the way it sits better and although I haven't been to the track yet it hooks better.
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #2 on: July 08, 2014 - 06:31:05 PM »
Any pics?
Offline 74challenger03
« Reply #3 on: July 08, 2014 - 08:33:25 PM »
would love to see some pics please
« Reply #4 on: July 09, 2014 - 09:43:36 AM »
I'd agree they are lighter in weight. They actually are much heavier in rate. I believe Cal-tracs are 200-225# rate whereas Mopar XHD springs are 160#.
Cal-tracs look like an effective method of suspension control. However, they were created by a Ford owner who was trying to duplicate Mopar's asymetrical spring action on his symetrical Ford springs within the rule limits of NHRA stock and super stock rules. If you need to adjust your spring and shock settings to track conditions, they may be a benefit. If you are a set it and forget it type, they may not be the hot ticket
Offline RCCDrew
« Reply #5 on: July 09, 2014 - 04:53:54 PM »
Very cool. Can they be bought with different spring rates? I know they are built for racing, but how does the ride compare with stock springs? I want the car to launch, but I want to keep my kidneys intact as well.
Offline challengerx
« Reply #6 on: July 09, 2014 - 11:18:29 PM »
I can post pics next weekend I'm on vacation and for some reason I don't have any pics of my car on my phone. As for the ride, I think it is way better than the ss. I do believe I had the heavier ss rate on mine.
Offline vinb
« Reply #7 on: July 15, 2014 - 06:28:58 PM »
Cal-Trac's with a Mono leaf set up on a Challenger stocker with a 9" slick..
« Last Edit: July 15, 2014 - 06:30:32 PM by vinb »
Offline HP_Cuda
  • Mopar or No Car!
« Reply #8 on: July 15, 2014 - 09:27:05 PM »
Ok Vin - what kind of shock is that?
I have a caltracs setup on my Yellow Cuda and it sure is stiffer. Once I put new shocks on the rear hopefully it will be a bit more tame.
« Reply #9 on: July 18, 2014 - 08:44:06 AM »
My experience using Caltracs was zero gain , 60" times were identical using stock leafs or Caltracs
Offline HP_Cuda
  • Mopar or No Car!
« Reply #10 on: July 18, 2014 - 03:35:55 PM »
Setup is key to get better 60 foot times.
Offline joelson6
« Reply #11 on: July 21, 2014 - 11:28:47 PM »
is there any weight transfer improvements with the cal tracs over SS springs?
« Reply #12 on: July 22, 2014 - 11:15:19 AM »
Caltracs were developed by a Ford racer in an effort to get the symetrical Ford springs to act like the Mopar asymetrical SS springs. They may have a couple more adjustment points than a standard SS pack and they may be abit easier to get those adjustments, but the overall operating principles are the same.
« Reply #13 on: July 23, 2014 - 05:41:38 PM »
& after adjusting lots we were able to duplicate the original 60' times , no improvement
Offline HP_Cuda
  • Mopar or No Car!
« Reply #14 on: July 23, 2014 - 07:59:00 PM »
In both upper and lower positions and only 1 more turn pre-load?
Btw, CP what kind of 60' times did you guys get?
Kinda simplistic but:
http://www.dcperformance.ca/category/37
