Author Topic: Dana 60 and new XHD leaf spring install.....good and bad results  (Read 4856 times)
Offline KillerBee
Got my new Dana 60 installed today along with the new MP XHD springs.
The good news is the Dana fit perfectly. :thumbsup:
The not so good news is as has been posted in the past the MP XHD leaf springs make the car sit TOO LOW. :eek4:
Like many have said the XHD springs make the car sit at factory ride height which might be OK for factory 14" wheels but for bigger 15" wheels and tires the car sits too low for me.
I'm also concerned that the XHD most likely will sag even more with use.
Thankfully Summit will take the springs back and with all new hardware the springs will be real easy to remove.
So I'll give ESPO a call tomorrow to price a set of +1 springs and option #2 is Dr. Diff suggested a pair of (soft) 3000lb. left side A body Super Stock springs which has the car sitting fairly low with good ride.
Small setback, actually swapping the rear end and springs went real easy, just another part of enjoying the Mopar hobby.
« Last Edit: July 09, 2014 - 06:48:24 PM by KillerBee »
Offline 74challenger03
Re: Dana 60 and new XHD leaf spring install.....good and bad results
« Reply #1 on: July 09, 2014 - 06:53:57 PM »
Feeling your pain on the springs. I ended up adding 2 springs to the set. Please post some pics when you get the springs.
Offline jhaag
« Reply #2 on: July 09, 2014 - 11:05:27 PM »
looks good to me. front sits too high.  :2cents:
love 70 Challengers
Offline Strawdawg
    • Vortex Buicks
« Reply #3 on: July 09, 2014 - 11:12:19 PM »
Bigger tires would have to make the car sit higher...Are you being confused because the larger tires go further into the wheel arch so you think the car is lower?
I agree that the car looks good to me but needs to have the torsion bars adjusted a little to drop the front end for a little rake.
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #4 on: July 10, 2014 - 12:12:48 AM »
I agree adjust the torsion bars down, which may also have an effect on the rear springs.  I was bottoming out my 17" wheels and had to have an extra leaf add to each side of mine.
Offline cordodge
« Reply #5 on: July 10, 2014 - 07:43:08 AM »
I did what dr diff suggested 3000lbs springs. here are some pics might be hard to tell as it is on dollies and once the motor and trans is in it should come down a bit more
1970 challenger 95% done
1969 roadrunner in progress
1969 D-100 13,000 mile truck
1969 L-700 tilt cab in progress
2007  Dodge Ram 4x4
2017 hyundia Santa fe ultimate
1977 VERY UNDERSTANDING WIFE !! 😇
Offline KillerBee
« Reply #6 on: July 10, 2014 - 08:44:11 AM »
Thanks for the post, car looks very nice.
Did you use 2 driver's side SS springs?
What size tires are on your car?
Offline KillerBee
« Reply #7 on: July 10, 2014 - 08:56:44 AM »
Thanks for the comments.
I did lower the front a pretty good amount before the pics...I can lower it even more but I'm starting to lose ground clearance and my local roads are terrible.
The rear tires are 275/60-15 and so far don't appear to rub anywhere but they go up inside the wheel well a little too much for me and I hear the XHD springs will probably sag even more over time. :eek4:
It seems the majority of XHD users end up adding another leaf eventually.
I would like to raise the rear about an 1" and not worry about the leafs sagging over time.
Offline cordodge
« Reply #8 on: July 10, 2014 - 09:44:18 AM »
thx, yes two driver side ss springs. the tires are 28x12 the springs are moved under the frame, the car should settle a touch more after the drive chain is installed  thx bruce
2007  Dodge Ram 4x4
Offline KillerBee
« Reply #9 on: July 10, 2014 - 06:20:19 PM »
Well I removed the MP XHD springs this morning and took them back to Summit Racing.
Replaced them with a pair of 3000lb. driver's side A body Super Stock springs.
Had to buy the E body SS extended front spring hangers and some smaller A body rubber bushings for the  rear leaf spring shackle eyelet.
Thankfully Summit had everything in stock.
I am very pleased with the results :clapping:
The car sits perfect...not too high not too low.
I can see the Dana rear end smiling at me now :grinyes:
I have the spring set in the higher hole on the front hanger.
I haven't driven it yet so I can't comment on the ride.
Hopefully tomorrow I'll get to take it on a road test.
« Last Edit: July 10, 2014 - 06:29:22 PM by KillerBee »
Offline cordodge
« Reply #10 on: July 10, 2014 - 07:17:10 PM »
looks good, glad you got it worked out.  bruce
2007  Dodge Ram 4x4
Offline Mpdlawdog
« Reply #11 on: July 10, 2014 - 07:22:54 PM »
I would keep the springs and lower the torsion bars...I like the way it sits  :2cents:....man you guys post fast!!!  glad it worked.....must be nice to live so close to Summit!!  I live in Delaware, OH...less than 5 minutes from Jegs!  They have save my butt a few times!!
cododge...your car is my poster child!  I have you pic printed out sitting on my windshield  :worshippy.....someday Ill get there!!
« Last Edit: July 10, 2014 - 07:28:32 PM by Mpdlawdog »
Offline cordodge
« Reply #12 on: July 11, 2014 - 07:54:39 AM »
hey thx very much mpdlawdog, I am sure you will get there it's been 6 years that I have been doing mine it takes time, money and patience but now that I am shooting for next summer to finish I am getting excited. take your time little by little and you'll get there.   bruce
2007  Dodge Ram 4x4
« Reply #13 on: July 15, 2014 - 12:44:46 PM »
Glad you found a spring combination that worked out the way you like it.
Put the remaining lug nuts in before your test ride!  :bigsmile:
Offline ChallengerHK
« Reply #14 on: July 15, 2014 - 12:50:05 PM »
Glad you got it worked out. Can I ask, what wheels are those?
- Han Solo, Star Wars
