Author Topic: 383 with 440 source head  (Read 1653 times)
Offline jwhit217
  • For a Chevy guy I sure have a lot of Mopars
« on: July 10, 2014 - 09:58:56 PM »
383  Magnum   .030 over TRW L2239     11:1 domed piston
440 source Alum heads
mopar purple .509 lift 272 dur
Edelbrock 650 thunder
Edelbrock dp intake
MSD6AL ignition
MSD pro billet distributor
mopar purple cam
727 torque flight
8 3/4    3.91 ratio
Offline cudabob496
Re: 383 with 440 source head
« Reply #1 on: July 10, 2014 - 10:52:24 PM »
seems the carb may be holding you back
I nice Holley 750 double pumper, dialed in, for that set up.
If mine, would also install a single plane intake.
2011 Kawasaki Z1000
Offline jimynick
« Reply #2 on: July 10, 2014 - 10:58:50 PM »
Good answer, but what was the question?  :dunno:
Offline Strawdawg
    • Vortex Buicks
« Reply #3 on: July 10, 2014 - 11:38:43 PM »
x2
Offline jwhit217
« Reply #4 on: July 12, 2014 - 12:16:02 AM »
I do have a holley sitting on the shelf, but for cruising the edelbrock is nice.  Spent more time tuning and fixing leaks on the holley. Plus no choke.
Offline Road_Runner
« Reply #5 on: July 14, 2014 - 08:02:36 AM »
Also not sure what feedback you're looking for.  Will say I ran a very similar setup in my 70 Roadrunner back in the 70's and it ran VERY strong.  I'll bet my cam might have been a touch better, but I only had massaged 906 heads so you definitely have me there.  Same intake with a either a 625 cfm Carter AVS similar to your Edelbrock or a 780 CFM Holley, when I wasn't running a sixpack on the car that is.  Up to a certain RPM it probably ran best with the Carter, when they were running right definitely the sixpack for racing.
Later, Jim
1970 383 Roadrunner Tor Red
1973 318 Barracuda Mist Green
Offline jwhit217
« Reply #6 on: July 14, 2014 - 10:17:47 PM »
No real Questions, lol.  Just wanted to post the combo. It seems a lot of people have reservations on the 440 heads.  I know i did.  But after getting a $900 quote on my 906 heads I took a chance.
Offline Road_Runner
« Reply #7 on: July 15, 2014 - 02:15:23 PM »
I've heard mostly good things about the 440Source heads so much so I bought a cnc'd set to go on the Roadrunner either on the 383 or 440 strokers.  leaning strongly to just stroking the 383 since the driveline is all original in a 44 year old car.   Plus, my goals for the car have changed from street/strip to just an extemely quick cool old cruise car.
Later, Jim:
