Okay Guys, I have been reading threads trying to determine what size wheel / tire I can fit without any mods to the car. The more I read, the more confused I get. Here is what is on the car currently. (by PO)
Front: P215 70 R14 (Ralley wheel) I do not know the width of this wheel. Maybe 6 or 7 inchs.....looks stock.
Rear: P275 60 R15 (Ralley Wheel) Again I do not know the width. These are wider than the front but I do not know by how much.
Now, I want to keep the 14 up front with the 15 in the back. I'm looking at the Crager S/S wheels (old school). Now the back space on the front wheel (Crager) is listed as 3.375. I believe the correct BS should be 4.50. The question for the front will this move the tire into the wheel well or out some? Would it look odd with this back space? Will this interfere with the disk brake caliper? I appears that there is plenty of room either way.
As for the rear, currently there is about an inch between the fender lip and tire as well as the tire and leaf spring, Now the Crager 15 X 8 (which I understand should fit into the wheel well without a problem) has a BS of 4.125. Can this work without issues? I intend to stay with the same size tires that are currently on the car. The rear tires need to be replaced but the front have very little wear.
Sorry, this may sound like a simple question to answer but I don't want to order something that I will have to return.
Thanks in advance.
