Author Topic: Performer RPM Air Gap  (Read 2162 times)
Offline flagcraig
« on: July 14, 2014 - 03:54:40 PM »
Made the choice to go with Edelbrock RPM Air Gap dual plane (7576) and a Holley Street Avenger 670 cfm.
I have a rallye 1972 Challenger rebuilt 340 with the factory sport hood.  Will it fit?  Can I use factory air cleaner or do I need to go with a new one?
Thanks for all the help.
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
Re: Performer RPM Air Gap
« Reply #1 on: July 14, 2014 - 04:09:58 PM »
Mine fits under a t/a hood with a 3in tall k&n, but just by the skin of it's teeth, so I would think u would maybe need a aftermarket air filter with a drop base
Scott in Omaha
2015 crew cab Hemi ram SOLD
2019 Ram Laramie
2016 Tahoe LTZ SOLD
1976 Ramcharger 383 4spd SOLD
2016 Audi
24 mopars past and 2 present
Offline soundcontrol
« Reply #2 on: July 14, 2014 - 04:12:34 PM »
I got a Edelbrock dual plane and a Holley Street Avanger on my 340, 70 Challenger, R/T hood. Have an Jegs aircleaner right now, and I have a lot of room.
I believe an factory air cleaner will fit also. Not sure about the model number on the intake but it looks the same if I check the picture of the 7576.
/ Ken
topic=108917.new#new
Offline 7212Mopar
« Reply #3 on: July 14, 2014 - 04:30:25 PM »
This is what I did last year. I choose the Edelbrock AVS 650
http://www.cuda-challenger.com/cc/index.php?topic=89646.30
1973 Challenger Rallye, AT with 1971 340
2012 Challenger SRT8 392 YJ,  6 spd
Offline calicuda70
  • 2 evil 70's and 1 BAD 11
« Reply #4 on: July 14, 2014 - 04:33:24 PM »
i have the same set up, have drop base aircleaner and and 3/8 carb spacer fits just barely also have solid motormount to help it from hitting the hood set up works great and the car pulls hard.
james
70 'Cuda 5.7 Hemi protouring resto
70 Challenger 360
11 Challenger SRT8 392
Offline cudabob496
2011 Kawasaki Z1000
Offline flagcraig
« Reply #6 on: July 16, 2014 - 01:17:29 PM »
Sounds like it could be a close call.  What if I dropped down to the 7176 Edelbrock intake which is the Performer RPM dual plane.  It looks like it gives me almost an extra inch to play with.  Will there be a dramatic change in performance?  Thanks.
Offline 7212Mopar
« Reply #7 on: July 16, 2014 - 03:19:32 PM »
http://www.hotrod.com/techarticles/hrdp_1111_differences_in_power_or_not_edelbrocks_rpm_vs_air_gap/
Air gap tuned 1000 RPM higher per Edelbrock.
I don't think you should have problem with a drop base air cleaner.
Offline cudabob496
« Reply #8 on: July 16, 2014 - 07:04:18 PM »
Dramatic change? Most swaps to a good intake will net you 15 to 20 hp or ft-lb torque. With your new carb, you
may even see more.  Good chance you'll feel in in the seat of your pants! But keep in mind, when you upgrade one
component, to see the max benefit, you need to possibly upgrade others, such as to a K&N air filter, or larger exhaust, etc.
On a 300 hp engine, a cold air induction system is worth about 20 hp.
PS I may have answered your question wrong. If you go from the air gap, to the Edelbrock performer dual plane, might lose about 10 peak hp/torque or so, in my opinion. The edelbrock performer dual plane I once had on my Cuda caused power to drop off quickly above 5500 rpm.
« Last Edit: July 16, 2014 - 09:50:01 PM by cudabob496 »
2011 Kawasaki Z1000
Offline HemiOrange70
« Reply #9 on: July 16, 2014 - 09:48:41 PM »
I have a 70 Challenger with 340 with airgap and Eddy carb with a 3" air cleaner and it fits fine
Offline cudabob496
« Reply #10 on: July 16, 2014 - 09:53:34 PM »
If you know the present adverized height of your intake, then put some playdough balls on the air cleaner, close hood,
then open hood and measure how much room you have from how much the playdough ball stayed un-squished.  Then look
at the advertized height of the intake you want to use, to caluculate if it will fit.  But you can make more room by modifying the base of your air cleaner.
Do all the modifications now, to lower height of air cleaner, and take measurements, before you buy the intake.
I also modified slightly the brackets that were under my hood, to make more room for a taller air filter.
« Last Edit: July 16, 2014 - 10:02:18 PM by cudabob496 »
2011 Kawasaki Z1000
