I would use forged pistons , if the bottom end is top quality you can do almost anything later without changing them out , I would use a steel crank though not hte cast one , you may find it cheaper to get a 408 CI stroker pkg & replace everyhting at once , J heads are OK but if you can find a set of 308 castings they will make more power if you are going to spend $ having large valves installed anyway
